Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Calculation of Q12 (Principal Shear Force in panels), and shear reinforcement ?
7 REPLIES 7
Message 1 of 8
lars.lrso
2406 Views, 7 Replies
I cant figure out how Q12 is calculated? And is it a correct way for showing the max shear force in a slab? (Calculations (need) of shear reinforcement in (foundations) slabs)
I have looked at following pages, but it does not make sense. (It works fine for M12 and N12 etc)
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-1279D686-429D-46F7-AE21-7E37F65C4D1-848.htm
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-BD23B817-BEE0-4DB2-97AF-2571B877F80-846.htm
 Lars
7 REPLIES 7
Message 2 of 8
Pawel.Pulak
in reply to: lars.lrso
Q(1-2) shear force is calculated as the resultant vector from QXX and QYY shear forces (Q(1-2) = sqrt (QXX^2 + QYY^2))
The state of stresses in panels is considered as 2D state of stresses with out-of-plane QXX and QYY shear forces considered as "extra" components.
That is why N, M, s  are transformed as tensors and Q is transformed as vector.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 3 of 8
lars.lrso
in reply to: Pawel.Pulak
Hi Pawel,
Thanks, for the quick answer.
I figured out that Q12 is the resultant vector. However when i calculate Q12 myself the numbers does not match with Robot. See the pictures attached.
/Lars
Message 4 of 8
jclcereno
I think QYY and QXX is not does not correlate to Q12...
Based from Robot Help:
Shear Forces: Qxx, Qyy. Adds columns for shear forces values Qxx or Qyy, respectively, for individual planar FEs in the local co-ordinate system as selected during structure analysis.
Shear Forces: Q12. If selected, it adds a column for maximum shear force values Q12 for individual planar FEs in the main coordinate system as selected during structure analysis.
Message 5 of 8
Tuctas
What about this observation, any conclusion..?
Message 6 of 8
Jummybear
in reply to: Tuctas
Same question here...
Message 7 of 8
Pawel.Pulak
in reply to: Jummybear
The reason of no correlation to the formula in some nodes is in low order and low precision of Finite Element shape function for Q shear force.
It can be noticed even displaying QXX or QYY without smoothing - like on the screen capture below. In such case is can be noticed that it is a linear function across finite elements.
Because of high inaccuracy of this function after smoothing the results (averaging in appropriate node from results of all finite elements connecting in this node)  the relation that Q(1-2)=sqrt(QXX^2+QYY^2) is lost. The averaging is done independently for QXX, QYY and Q(1-2).
It is OK and the relation is kept for results in the centroids of finite elements or for results without smoothing - as on the screen capture below.
Best regards,
Pawel Pulak
Message 8 of 8
Tuctas
Very well explained Pawel. Thank you
