Hi
Please find the attached file.
"Calculations not performed" message:
The bar is assigned:
Type: RC Beam
Structure object: Beam
What should I do to solve this error?
Try to add display of Remarks to the visible columns of the table and check what is written there.
Hi Artur
Remarks is displayed as it is apparent in the first post.
I just had the same kind of "problem" but my solution was simple:
My bar cross section was made as "RC beam" and I tried to add RC member type properties as Column to them.
When I changed my bar cross sections to the new one, made as RC column section, then I was able to add RC member type properties as it is a column, and calculation (reinforcement calculation) was successful.
Hi @Artur.Kosakowski and thank you for your help in advance.
I am experiencing a similar issue but even though I displayed the remarks column in the table ticking Table Columns>Remarks, I still cannot see more details about the error and it shows "Calculation-not performed".
Can I ask you some help in this regard? (screenshots attached)
Many thanks.
Hi @adrian37UXU
Have you entered numbers of combinations in the load case selection fields? If yes, zip and attach the Robot model.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
