Hi everyone,
Is there someone that can tell me where can I find a calculation log file of the current Robot model? I'm working with a very big model (~81000 beams) and I need to know the detailed calculation times to organize my work time. I left my PC running in the day as in the night and I can't check the duration of each phase watching the log panel.
Greetings at all
Solved by Artur.Kosakowski. Go to Solution.
http://forums.autodesk.com/t5/Robot-Structural-Analysis/Log-of-analysis-errors/m-p/3505326
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
