Calculation errors rc plate
9 REPLIES 9
Message 1 of 10
pevelor
515 Views, 9 Replies
Hi
I run provided reinforcement for a simple two way slab and I encounter some errors.
Link to file: https://dl.dropboxusercontent.com/u/61406729/Structure%201.rtd
What is wrong and how do I correct it?
In advance, thanks
Peder
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
in reply to: pevelor
The link seems to be corrupted.
Artur Kosakowski
Message 3 of 10
pevelor
in reply to: Artur.Kosakowski
I'm sorry, I had the file open on my computer. Should be working fine now.
Message 4 of 10
Artur.Kosakowski
This is what I get:
Artur Kosakowski
Message 5 of 10
pevelor
I'm an idiot. I had paused file syncing on dropbox:-)
Now it should be working.
Message 6 of 10
Artur.Kosakowski
I think the warning aboout the cover is excessive and is probably caused by the fact that you used different diamertes of rebars which 'confused' the implemented check procedure. We will investigate this situation.
For the concreter strenth see below:
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 7 of 10
pevelor
Thanks for your reply.
As I understand, the error is telling only that the combination concrete strenght and v/c number is wrong. Please let me now if I misunderstood this.
Recently (last coulpe of years), concrete suppliers have come up with a new recipe that reads B35/M40. This combination is now widely used and should not result in errors in RSA.
Message 8 of 10
Artur.Kosakowski
Is 'v/c number' what is displayed in the top row of the table I attached e.g. M40?
Artur Kosakowski
Message 9 of 10
pevelor
Yes, thats correct. M40 is the same as water sement ratio. I probably should have used the word durability.
Message 10 of 10
Artur.Kosakowski
Robot displays warning based on the content of the mentioned table which is as published in the design code. If you have the material that you know is correct  just ignore ignore it.
Artur Kosakowski
