Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
arunmoses
362 Views, 3 Replies
cable net facade
hi,
i am trying to solve this cable net facade, facing an huge defficulty in analysis,
kindly support
arun
3 REPLIES 3
You either need to redefine boundary condition or change the model type to 2D frame (attached). In addition P-Delta is needed for all load cases.
Artur Kosakowski
in reply to: Artur.Kosakowski
thank you very much for your instance support. just a small query is it possible to estimate pretenion from relative elongation value. need your thoughts.
thank you once again.
Arun
Artur.Kosakowski
Available in the stresses table.
See also http://forums.autodesk.com/t5/Robot-Structural-Analysis/Cable-assembly-force-and-regulation-distance...
Artur Kosakowski
