Hello, I am just wondering why I can't reveal the envelope axial forces in cables for my all combinations! I can see axial load diagram for each load case but when I select combinations nothing appears!! is that a bug or that is something that Robot does not show?!
Solved by Rafal.Gaweda. Go to Solution.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
It should work. Please check if you have SP3 installed.
If it is not the case please send me your model.
Envelope on cables can not be displayed if any of the cases \ combinations makes such cable "turned off".
Example on your model : cable 12 comb 205. So if 205 is included in any envelope for cables you will see no diagram.
I will let developers know about that. Thanks for reporting.
