Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Cable axial force results
4 REPLIES 4
mgaafar
564 Views, 4 Replies
Hello, I am just wondering why I can't reveal the envelope axial forces in cables for my all combinations! I can see axial load diagram for each load case but when I select combinations nothing appears!! is that a bug or that is something that Robot does not show?!
Tags (1)
4 REPLIES 4
Romanich
in reply to: mgaafar
You can't, because in case of the nonlinearity principle of superposition is not valid.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Rafal.Gaweda
It should work. Please check if you have  SP3 installed.
If it is not the case please send me your model.
Rafal Gaweda
mgaafar
My RSA is up to date tp SP3, and the model will be sent to your inbox Rafal
Thanks.
Rafal.Gaweda
Envelope on cables can not be displayed if any of the cases \ combinations makes such cable "turned off".
Example on your model :  cable 12 comb 205. So if 205 is included in any envelope for cables you will see no diagram.
I will let developers know about that. Thanks for reporting.
Rafal Gaweda
