I started programming C# RSA , I have difficulties to translate code from vb to c#. Please help me .
please write sample code
how to change:
1) tools / job preferences / materials / basic set / steel
how to change type of steel for example: put S355
RobotMaterialData Material;
2) how to
create a new section
standard
Database: Simple Catpro Family: HEA Section: HEA120 Section type Aluminum
3) on the http://www.robobat.com/n/ros/
There is a code In vb , I couldn’t translate all to c#, please correct me
It is original code:
Reading the basic geometry
Declare the main variable representing the Robot application and connect it to the currently running instance of Robot.
Dim robapp As IRobotApplication
Set robapp = New RobotApplication
Get the collection of all bars from the structure.
Set bar_col = robapp.Project.Structure.Bars.GetAll()
Iterate for consecutive bars from the collection.
For i = 1 To bar_col.Count
Get the object representing the following (i-th) bar in the collection.
Set bar = bar_col.Get(i)
Read required attributes of the i-th bar.
bar_num = bar.Number
start_node_num = bar.StartNode
end_node_num = bar.EndNode
Declare variables defining individual nodes.
Dim start_node As IRobotNode, end_node As IRobotNode
Get the node with start_node_num number from the server.
Set start_node = robapp.Project.Structure.Nodes.Get(start_node_num)
Read the values of coordinates x, y, z for the node with start_node_num number.
start_node_x = start_node.X
start_node_y = start_node.Y
start_node_z = start_node.Z
Get the node with end_node_num from the server and read its coordinates.
Set end_node = robapp.Project.Structure.Nodes.Get(end_node_num)
end_node_x = end_node.X
end_node_y = end_node.Y
end_node_z = end_node.Z
Free all declared variable references.
Set bar = Nothing
Set start_node = Nothing
Set end_node = Nothing
Repeat the operation of reading data for the next bar from the collection.
Next
Free all the references declared in the example.
Set bar_col = Nothing
Set robapp = Nothing
Mine code:
IRobotApplication robApp;
robApp = new RobotApplicationClass();
IRobotCollection bar_col = robApp.Project.Structure.Bars.GetAll();
for (int i = 0; i <= Convert.ToInt32(bar_col.Count); i++)
// IRobotBar bar = bar_col.Get(i);
// this below is something wrong
IRobotBar bar = robApp.Project.Structure.Bars.Get(i);
Error 1 Cannot implicitly convert type 'RobotOM.IRobotDataObject' to 'RobotOM.IRobotBar'. An explicit conversion exists (are you missing a cast?) G:\nauka c# cad\Robot02\Robot02\Form1.cs
4) Remove selected load cases
Declare the main variable representing Robot aplication and its connection to the currently running program instance.
Dim casesrv As IRobotCaseServer
Set casesrv = robapp.Project.Structure.Cases
Get the collection including all load cases.
Dim casecol As IRobotCaseCollection
Set casecol = robapp.Project.Structure.Cases.GetAll()
Iterate for consecutive cases from the collection.
For i = 1 To casecol.Count
Get i-th case
Dim c As IRobotCase
Set c = casecol.Get(i)
Remove the case from the server if the analysis type is different from the linear static analysis.
If c.AnalizeType <> I_CAT_STATIC_LINEAR Then casesrv.Delete c.Number
Free variable representing a case
Set c = Nothing
Repeat the iteration for the following case.
Next
Mine code:
IRobotCaseServer casesrv;
casesrv = robApp.Project.Structure.Cases;
IRobotCaseCollection casecol;
casecol = robApp.Project.Structure.Cases.GetAll();
for (int i = 0; i <= Convert.ToInt32(casecol.Count); i++)
IRobotCase c;
c = Convert.ToInt32(casecol.Get(i));
if (c.AnalizeType != IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
casesrv.Delete(c);
5)
IRobotStructure str;
str = robApp.Project.Structure;
// Generate new load case.
IRobotSimpleCase caseExp;
caseExp = robApp.Project.Structure.Cases.CreateSimple(str.Cases.FreeNumber, "caseExp",
IRobotCaseNature.I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR);
// Define load record types.
caseExp.Records.New(IRobotLoadRecordType.I_LRT_NODE_FORCE);
IRobotLoadRecord LoadRecord; // rec
LoadRecord = (RobotLoadRecord)caseExp.Records.Get(1);
LoadRecord.SetValue(IRobotBarUniformRecordValues.I_BURV_LOCAL, true);
6)
IRobotViewDisplayParams ParamsDisplay01;
ParamsDisplay01 = ? (how to declare )
ParamsDisplay01.Set(IRobotViewDisplayAttributes.I_VDA_STRUCTURE_NODE_NUMBERS, true);
Solved by Rafal.Gaweda. Go to Solution.
Mine code:
Should be:
IRobotApplication robApp = new RobotApplication(); IRobotCollection bar_col = robApp.Project.Structure.Bars.GetAll(); for (int i = 0; i < bar_col.Count; i++) { IRobotBar bar = bar_col.Get(i+1); // or // IRobotBar bar = (IRobotBar)robApp.Project.Structure.Bars.Get(i+1); }
Mine code:
IRobotCase c;
casesrv.Delete(c);
Should be
IRobotCaseServer casesrv = robApp.Project.Structure.Cases; IRobotCaseCollection casecol= casesrv.GetAll(); for (int i = 0; i < Convert.ToInt32(casecol.Count); i++) { IRobotCase c = casecol.Get(i+1); if (c.AnalizeType != IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR) { casesrv.Delete(c.Number); }
5)
I assume you want to add nodal force:
IRobotStructure str = robApp.Project.Structure; // Generate new load case. IRobotSimpleCase caseExp; caseExp = robApp.Project.Structure.Cases.CreateSimple(str.Cases.FreeNumber, "caseExp", IRobotCaseNature.I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR); // Define load record types. caseExp.Records.New(IRobotLoadRecordType.I_LRT_NODE_FORCE); IRobotLoadRecord LoadRecord = caseExp.Records.Get(caseExp.Records.Count); LoadRecord.SetValue((short)RobotOM.IRobotNodeForceRecordValues.I_NFRV_FZ,-10); LoadRecord.Objects.FromText ("1") ;
Should be
IRobotView robotview = robApp.Project.ViewMngr.GetView(1); robotview.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_STRUCTURE_NODE_NUMBERS, true);
Thank You
Your solution for these points is proper.
If You don't mind please writethe 1) and 2)
2) how to create a new section
New profile
standard Database: Simple Catpro
I tried myself but it is not what I would like to achieve:
IRobotProjectPreferences ProjectPrefs;
ProjectPrefs = robApp.Project.Preferences;
ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_RC_THEORETICAL_REINF, "BAEL91");
IRobotMaterialDatabase material;
material = ProjectPrefs.Materials;
// material.Name = IRobotMaterialDatabase
Material = (RobotMaterialData)label.Data;
Material.Type = IRobotMaterialType.I_MT_CONCRETE;
I hope you meant this:
robApp.Project.Preferences.Materials.Load("Eurocode"); RobotBar Bar = (RobotBar)robApp.Project.Structure.Bars.Get(bar_number); Bar.SetLabel(IRobotLabelType.I_LT_MATERIAL, "S355");
New profile
robApp.Project.Preferences.SetCurrentDatabase(IRobotDatabaseType.I_DT_SECTIONS, "SIMPL"); IRobotLabel Section = robApp.Project.Structure.Labels.Create(IRobotLabelType.I_LT_BAR_SECTION,"HEA 120"); IRobotBarSectionData SData = Section.Data; SData.LoadFromDBase("HEA 120"); robApp.Project.Structure.Labels.Store(Section); RobotBar Bar = (RobotBar)robApp.Project.Structure.Bars.Get(bar_number); Bar.SetLabel(IRobotLabelType.I_LT_BAR_SECTION, "HEA 120");
