Message 1 of 8
2535 Views, 7 Replies
C# API help
I started programming C# RSA , I have difficulties to translate code from vb to c#. Please help me .
please write sample code
how to change:
1) tools / job preferences / materials / basic set / steel
   how to change type of steel for example: put S355
RobotMaterialData Material;
2) how to
  create a new section
  standard
Database: Simple Catpro        Family:  HEA         Section: HEA120         Section type Aluminum
3)  on the http://www.robobat.com/n/ros/
There is a code In vb , I couldn’t translate all to c#, please correct me
It is original code:
Reading the basic geometry
Declare the main variable representing the Robot application and connect it to the currently running instance of Robot.
Dim robapp As IRobotApplication
Set robapp = New RobotApplication
  Get the collection of all bars from the structure.
Set bar_col = robapp.Project.Structure.Bars.GetAll()
  Iterate for consecutive bars from the collection.
For i = 1 To bar_col.Count
    Get the object representing the following (i-th) bar in the collection.
Set bar = bar_col.Get(i)
    Read required attributes of the i-th bar.
bar_num = bar.Number
start_node_num = bar.StartNode
end_node_num = bar.EndNode
    Declare variables defining individual nodes.
Dim start_node As IRobotNode, end_node As IRobotNode
    Get the node with start_node_num number from the server.
Set start_node = robapp.Project.Structure.Nodes.Get(start_node_num)
    Read the values of coordinates x, y, z for the node with start_node_num number.
start_node_x = start_node.X
start_node_y = start_node.Y
start_node_z = start_node.Z
    Get the node with end_node_num from the server and read its coordinates.
Set end_node = robapp.Project.Structure.Nodes.Get(end_node_num)
end_node_x = end_node.X
end_node_y = end_node.Y
end_node_z = end_node.Z
    Free all declared variable references.
Set bar = Nothing
Set start_node = Nothing
Set end_node = Nothing
  Repeat the operation of reading data for the next bar from the collection.
Next
  Free all the references declared in the example.
Set bar_col = Nothing
Set robapp = Nothing
Mine code:
IRobotApplication robApp;
  robApp = new RobotApplicationClass();
   IRobotCollection bar_col = robApp.Project.Structure.Bars.GetAll();
           for (int i = 0; i <= Convert.ToInt32(bar_col.Count); i++)
           //   IRobotBar bar = bar_col.Get(i);
// this below is something wrong
                IRobotBar bar = robApp.Project.Structure.Bars.Get(i);
Error      1             Cannot implicitly convert type 'RobotOM.IRobotDataObject' to 'RobotOM.IRobotBar'. An explicit conversion exists (are you missing a cast?) G:\nauka c# cad\Robot02\Robot02\Form1.cs
4) Remove selected load cases
Declare the main variable representing Robot aplication and its connection to the currently running program instance.
Dim casesrv As IRobotCaseServer
Set casesrv = robapp.Project.Structure.Cases
  Get the collection including all load cases.
Dim casecol As IRobotCaseCollection
Set casecol = robapp.Project.Structure.Cases.GetAll()
  Iterate for consecutive cases from the collection.
For i = 1 To casecol.Count
    Get i-th case
Dim c As IRobotCase
Set c = casecol.Get(i)
    Remove the case from the server if the analysis type is different from the linear static analysis.
If c.AnalizeType <> I_CAT_STATIC_LINEAR Then casesrv.Delete c.Number
    Free variable representing a case
Set c = Nothing
  Repeat the iteration for the following case.
Next
Mine code:
           IRobotCaseServer casesrv;
           casesrv = robApp.Project.Structure.Cases;
           IRobotCaseCollection casecol;
           casecol = robApp.Project.Structure.Cases.GetAll();
           for (int i = 0; i <= Convert.ToInt32(casecol.Count); i++)
               IRobotCase c;
               c = Convert.ToInt32(casecol.Get(i));
               if (c.AnalizeType != IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
casesrv.Delete(c);
5)
            IRobotStructure str;
            str = robApp.Project.Structure;
            // Generate new load case.
            IRobotSimpleCase caseExp;
            caseExp = robApp.Project.Structure.Cases.CreateSimple(str.Cases.FreeNumber, "caseExp",
                IRobotCaseNature.I_CN_EXPLOATATION, IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR);
            //      Define load record types.
            caseExp.Records.New(IRobotLoadRecordType.I_LRT_NODE_FORCE);
  IRobotLoadRecord LoadRecord; // rec
  LoadRecord = (RobotLoadRecord)caseExp.Records.Get(1);
LoadRecord.SetValue(IRobotBarUniformRecordValues.I_BURV_LOCAL, true);
6)
IRobotViewDisplayParams ParamsDisplay01;
ParamsDisplay01 = ?  (how to declare  )
    ParamsDisplay01.Set(IRobotViewDisplayAttributes.I_VDA_STRUCTURE_NODE_NUMBERS, true);
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
Mine code:
Should be:
            IRobotApplication robApp = new RobotApplication();
            for (int i = 0; i < bar_col.Count; i++)
                   IRobotBar bar = bar_col.Get(i+1);
                // or
               // IRobotBar bar = (IRobotBar)robApp.Project.Structure.Bars.Get(i+1);
Rafal Gaweda
Message 3 of 8
Rafal.Gaweda
Mine code:
               IRobotCase c;
casesrv.Delete(c);
Should be
           IRobotCaseServer casesrv = robApp.Project.Structure.Cases;
           IRobotCaseCollection casecol= casesrv.GetAll();
           for (int i = 0; i < Convert.ToInt32(casecol.Count); i++)
               IRobotCase c = casecol.Get(i+1);
                casesrv.Delete(c.Number);
Rafal Gaweda
Message 4 of 8
Rafal.Gaweda
5)
I assume you want to add nodal force:
            IRobotStructure str = robApp.Project.Structure;
  IRobotLoadRecord LoadRecord = caseExp.Records.Get(caseExp.Records.Count);
LoadRecord.SetValue((short)RobotOM.IRobotNodeForceRecordValues.I_NFRV_FZ,-10);
            LoadRecord.Objects.FromText ("1") ;
Rafal Gaweda
Message 5 of 8
Rafal.Gaweda
Should be
            IRobotView robotview = robApp.Project.ViewMngr.GetView(1);
            robotview.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_STRUCTURE_NODE_NUMBERS, true);
Rafal Gaweda
Message 6 of 8
in reply to: Rafal.Gaweda
Thank You
Your solution for these points is proper.
If You don't mind please writethe 1) and 2)
2) how to   create a new section
  New profile
    standard   Database: Simple Catpro
I tried myself but it is not what I would like to achieve:
            IRobotProjectPreferences ProjectPrefs;
            ProjectPrefs = robApp.Project.Preferences;
            ProjectPrefs.SetActiveCode(IRobotCodeType.I_CT_RC_THEORETICAL_REINF, "BAEL91");
            IRobotMaterialDatabase material;
            material = ProjectPrefs.Materials;
           // material.Name = IRobotMaterialDatabase
            Material = (RobotMaterialData)label.Data;
            Material.Type = IRobotMaterialType.I_MT_CONCRETE;
Message 7 of 8
Rafal.Gaweda
I hope you meant this:
            robApp.Project.Preferences.Materials.Load("Eurocode");
            RobotBar Bar = (RobotBar)robApp.Project.Structure.Bars.Get(bar_number);
            Bar.SetLabel(IRobotLabelType.I_LT_MATERIAL, "S355");
Rafal Gaweda
Message 8 of 8
Rafal.Gaweda
  New profile
robApp.Project.Preferences.SetCurrentDatabase(IRobotDatabaseType.I_DT_SECTIONS, "SIMPL");
IRobotLabel Section = robApp.Project.Structure.Labels.Create(IRobotLabelType.I_LT_BAR_SECTION,"HEA 120");
IRobotBarSectionData SData = Section.Data;
SData.LoadFromDBase("HEA 120");
robApp.Project.Structure.Labels.Store(Section);
Bar.SetLabel(IRobotLabelType.I_LT_BAR_SECTION, "HEA 120");
Rafal Gaweda
