Hi
I wish ARSA be the best.
How to model such a problem:
A wooden cylinder 600mm in diameter, relative density 0.5, has a concrete cylinder 600mm long of the same diameter, relative density 2.5, attached to one end. Determine the length of wooden cylinder for the system to float in stable equilibrium with axis vertical.
@HoshangMustafa wrote:Hi
Manual Computation is easier.
Actually RSAP won't tell you if the system is stable. you just have to create your own check or have design parameters to make it work.
