When you sort the member verification list by ratio to check which bar is most demanding...after doing that the MAP button doesn't work any more. You have to run again the verification and click MAP before sort the list.
Other useful thing to be included in the software (I already put in the wishlist) is to directly highlight the bar in the model when you pick it in the verification list. Otherwise you have to type the number of the bar in the bar box to select and then to identify in the model for every bar you want to identify.
Regards
Thanks for reporting.
