I think there is a bug in the calculation of this coupling in Robot 2014.
You might check?
Solved by Artur.Kosakowski. Go to Solution.
Could you attach the file with this connection please? Thank you.
This connection type is assumed as the category A. Please use 8.8 bolts instead (do not use HR and HV ones).
