Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
bug in Revit to Robot
1 REPLY 1
Leader_Mohamed
312 Views, 1 Reply
Hi everyone,
If I have a predefined column section in Robot with a name, for example "column 1 " with dimension  300x700 and I define the same name to column section in my Revit project 250x300
When I use Revit to Robot integration the exported section takes the dimension of the section defined in Robot not in Revit.
any solution ?
movie http://www.screencast.com/users/Leader_Mohamed/folders/Jing/media/341d8a60-cf6e-480e-b996-ee33d5bfd7...
1 REPLY 1
This is correct. Standard sections are matched internaly by section type and dimensions, not by name.
Rafal Gaweda
