Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Bug in panel display
2 REPLIES 2
tony.ridley
418 Views, 2 Replies
I have a frustrating problem;
When i draw a poly line and extrude it to make a curved panel, I get the problem described here;
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Thickness-of-extruded-element/td-p/4347012
I cannot make a thickness appear in the object inspector.
So i create FE mesh on this, and then I use panel creation with a list of FE's to create the curved panel that I want.  See pic 1;
I then either use mirror or rotate to copy the panel to make a tube.  Then this happens;
Why?  Why is drawing circular / curved panels in Robot so frustrating?
If I leave it just as an extruded polyline (i.e. not using mesh then create panel with FE's), the edges are defined in a way that does not let me apply loads or apply edge releases properly.
Tony
2 REPLIES 2
Tony,
The option of converting extruded objects into panels is on the wish list. On the other hand I can't see any problems with applying linear releases or loads on edges.
Mind that you can create this object in the different way:
1. Define an arc
2. Copy it above
3. Link two arches with side lines
4. Use these 4 objects to create a panel.
Artur Kosakowski
Nice one.  Didn't think of that method.  Thank you
