hi,
i have a simple column with pinned botom (ux,uy and Rz fixed) and a roler at z axis at the top (ux uy fixed).
i apply a vertikal load at the top and the calculation mode is non linear p-delta.
my question is why i do not see the colunn buckling and deformation?
i only see the displacement in the z axis at the top but no bending. the buckling analysis show that the column is under excesive force but even if i increase the load in very large amounts the deformation is only axial.
is there a way in robot to see the REAL deformation and bending or torsional behavior?
what am i doing wrong?
thanks
Have you run buckling analysis ?
