Hi all,
Every time i try to use Buckling Analysis in non symmetric and non regular structure i get really confused how to deal with it.
Please check random model in attachment. It has buckling analysis on combination 12 and i get alfacr<10 for first mode, how can i know if this mode is relevant or not? By checking mode shape i cannot get an answer to my question, have you?
Tips and tricks are appreciated, i'm always feeling that i'm not taking advantage of robot capabilities.
Thanks in advance,
RR
Solved by Pawel.Pulak. Go to Solution.
check the % of total mass it uses.The more mass , the more relevant
Rafael Medeiros
Hi Rafacascudo,
I'm refering to buckling modes not modal analysis, i think that's not possible on ARSA to see that on the first issue.
It is visible that for the attached model the buckling mode 1 is related to buckling in global Y direction.
See this video:
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Thanks pp2008, i suppose that doesn't exist a straight way then guess it by mode shapes.
I guess you're right.
Sometimes it is pretty obvious, sometimes is not. Sometimes the structure is just not well modeled and one needs to change some kind of realese and /or bar stiffness. When I get "weird" modes I try to model the structure in a different way...bu it can be confusing, as the structure gets more complicated.
