Discussion Groups
Robot Structural Analysis
Active Member
LLAL
bracket length is greater (or equal) than bar length/greater than bar length
177 Views, 5 Replies
07-24-2012 06:09 AM
Good day all,
  I have been using brackets for quite a while and have never had any problems. When I ran a "verification" of my model, I received 2 error messages : "Bracket length is greater (or equal) than bar length" and "Total length of bracket is greater than bar length".
I have used the same settings that I always use (see attach) for the brackets. Can anyone assist?
Eric
Please use plain text.
Product Support
Rafal.Gaweda
Re: bracket length is greater (or equal) than bar length/greater than bar length
07-24-2012 06:38 AM in reply to: LLAL
Check where you have not wrongly defined bracket length in relative unit (0 to 1)
Rafal Gaweda
Участник
07-25-2012 11:01 AM in reply to: LLAL
I also received this message when re-calculating the model after selection/collection of 'Phases'.
Bracket parameters set to relative or absolute doesn’t seem to matter.
Brackets are not compatible with Phases?
Active Member
LLAL
07-25-2012 11:30 AM in reply to: Rafal.Gaweda
I don't think the parameters were the problem. I double checked and even reset them.
However I proceeded to complete the rest of the model, (loads, cladding etc) and the error message dissappeared.
Eric
Product Support
Rafal.Gaweda
07-26-2012 12:16 AM in reply to: Участник
I do not see any problem with brackets \ brackets + phases.
If you have such model plwease send us.
Rafal Gaweda
Участник
07-26-2012 02:07 AM in reply to: LLAL
Message disappeared after some manipulations in ‘Phase collection’ dialog. Probably just a glitch.
