Good day all,
I have been using brackets for quite a while and have never had any problems. When I ran a "verification" of my model, I received 2 error messages : "Bracket length is greater (or equal) than bar length" and "Total length of bracket is greater than bar length".
I have used the same settings that I always use (see attach) for the brackets. Can anyone assist?
Eric
Check where you have not wrongly defined bracket length in relative unit (0 to 1)
I also received this message when re-calculating the model after selection/collection of 'Phases'.
Bracket parameters set to relative or absolute doesn’t seem to matter.
Brackets are not compatible with Phases?
I don't think the parameters were the problem. I double checked and even reset them.
However I proceeded to complete the rest of the model, (loads, cladding etc) and the error message dissappeared.
Eric
I do not see any problem with brackets \ brackets + phases.
If you have such model plwease send us.
