Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
bracket length is greater (or equal) than bar length/greater than bar length
5 REPLIES 5
LLAL
635 Views, 5 Replies
Good day all,
  I have been using brackets for quite a while and have never had any problems. When I ran a "verification" of my model, I received 2 error messages : "Bracket length is greater (or equal) than bar length" and "Total length of bracket is greater than bar length".
I have used the same settings that I always use (see attach) for the brackets. Can anyone assist?
Eric
5 REPLIES 5
Rafal.Gaweda
in reply to: LLAL
Check where you have not wrongly defined bracket length in relative unit (0 to 1)
Rafal Gaweda
Участник
in reply to: LLAL
I also received this message when re-calculating the model after selection/collection of 'Phases'.
Bracket parameters set to relative or absolute doesn’t seem to matter.
Brackets are not compatible with Phases?
LLAL
in reply to: Rafal.Gaweda
I don't think the parameters were the problem. I double checked and even reset them.
However I proceeded to complete the rest of the model, (loads, cladding etc) and the error message dissappeared.
Eric
I do not see any problem with brackets \ brackets + phases.
If you have such model plwease send us.
Rafal Gaweda
Участник
in reply to: LLAL
Message disappeared after some manipulations in ‘Phase collection’ dialog. Probably just a glitch.
