Discussion Groups
Robot Structural Analysis
GabrieleNovembri1027
Accepted Solution
Boolean operations in building type structure
203 Views, 2 Replies
01-24-2012 08:43 PM
Hi All,
may be a stupid question but:
How I can use the Boolean operators in a building type structure ?:
In the example file of the ICK the Boolean operators are available despite the structure file type. This not happen in my case:
Why ?
Please use plain text.
Product Support
pp2008
Re: Boolean operations in building type structure
01-25-2012 12:37 AM in reply to: GabrieleNovembri1027
by default Boolean operations are not available in Building Design type of structure to simplify the interface and because these commands are ussually not used there.
If necessary you can use Tools>Customize>Customize Menu to add them in Edit menu. See the attached screen capture.
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
01-25-2012 03:01 AM in reply to: pp2008
Great Pawel.
