Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Bolt yield stress error value
3 REPLIES 3
331 Views, 3 Replies
Dear Support,
I am using ARSA 2015 SP3 WIN 7 PRO.
In some bolt database like:
the bolt yield stress fyb  of some bolt classes are not conform to NF EN 1993 1-8 table 3.1.
see the following value of fyb for bolt class 8.8 in RSA:
this value is different from fyb=640 Mpa found in table 3.1.
I made some tests and found that some bolt class fyb values are correct the other are not.
Please advise.
Thank you in advance.
Wassim
3 REPLIES 3
Artur.Kosakowski
NF is for CM66. Use ISO database instead.
Artur Kosakowski
in reply to: Artur.Kosakowski
You are right Artur, the EN ISO bolt database has valid yield stress values !
But I suggest that software gives some warnings of the database incompatibility with the used code (We have the same name of the bolt type between NF and the EN ISO ; Example Bolt  class   8.8 ;   4.6....)
Thank you very much.
Wassim
