Blue Screen of Death saga
8 REPLIES 8
Message 1 of 9
tony.ridley
745 Views, 8 Replies
Hi guys,
When I print from Robot 2012 it causes crash of entire PC.
It happens when I print tables such as reactions.
It happens when I print to a physical printer, but print to PDF causes no issue.
I'm on a 64bit Windows 7 PC.  It's also happening on other PC's in this office.  I tried to uninstall IE9 as previously instructed but it makes no difference.
Any suggestions (aside from the obvious ones - was installed with full admin rights etc etc).
8 REPLIES 8
Message 2 of 9
Are you sure you have uninstalled IE9 ?
Maybe (because such possibility exists in Win 7) have you just disable it, and just disable it doen't change anything to Blue Screen crash while printing ?
http://windows.microsoft.com/en-US/windows7/how-do-i-install-or-uninstall-internet-explorer-9
Francois Augiere
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 9
gliga
in reply to: Francois.Augiere
In my case uninstaling IE9 solved printing tables problem.
But, please, fix this incredible bug (bug in IE9 is less possible) to be able to have both (RSA2012 and IE9)
Gliga
Message 4 of 9
Francois.Augiere
in reply to: gliga
Some change has been made in version 9 of IE concerning HTML rendering engine.
This issue is currently under investigation
If my post answers your question, please click the "Accepted as Solution" button. This helps everyone find answers more quickly !
Francois Augiere
Support Specialist
Product Support
Autodesk, Inc.
Message 5 of 9
in reply to: tony.ridley
I had the same problem and uninstalled IE9.
It seems that it's working now, but another related problem still exist. When I want to print a table, its columns width (and generally table formatting) are printed by a default settings, even if I adjusted the width and alignment on the screen. That makes larger tables to be printed on more pages with unnecessarily wide table columns. Do you have any idea how can I fix the problem?
Mark
Message 6 of 9
gliga
Problem with table arrangement could be overcomes on acceptable way by exporting tables to word
It work fine and it look like IN WORD tables are like prepared in ROBOT before ScreenShot was take (column width, etc).
But I agree that this is frustrated (and was not like now in previous version) when officially way for result preparing does not work on acceptable way.
Gliga
Message 7 of 9
Rafal.Gaweda
It should be corrected in SP3 for arsa 2012.
SP3 will be released soon.
Rafal Gaweda
Message 8 of 9
tony.ridley
in reply to: Rafal.Gaweda
Rafal,
Is the SP3 fix you refer to going to fix the table width formatting problem, or the blue screen problem itself.
The width of the columns is unimportant if the pc crashes anyway!
Cheers,
Message 9 of 9
Rafal.Gaweda
Tony,
Table width formatting is planned to be corrected.
For now there are (known for us) 2 workarounds for BSOD:
- uninstalling IE9
- installing the newest available printer dirvers (in some case = in case of some printers it helped)
Rafal Gaweda
