Discussion Groups
Robot Structural Analysis
Athi_uk
Bending moment in Panel cuts
312 Views, 1 Replies
11-04-2011 07:11 AM
Can you please explain me about the Mxx , Myy and Mxy moments which can be obtained from the panel cuts in a slab design? i.e Mxx is which direction or simply showing all the moments in a sketch.
James
Please use plain text.
Product Support
Artur.Kosakowski
Re: Bending moment in Panel cuts
11-04-2011 07:39 AM in reply to: Athi_uk
Please check these two topics of Help
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-E73EA3A2-AEC8-40EA-8AC3-E7EDCA7644C-740.htm
http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-16AA1074-A4F2-4EAA-A456-86AF1F39634-742.htm
Artur Kosakowski
