Hi I am very new to robot and i am trying to check my statics model using robot.
I am trying to make a 2D frame of a steel frame. See attached foto.
The model is supposed to be: Pinned in each side, and charnie at the top, meaning that the moment should be zero.
Nomatter what i do i get a moment at the top, what am i doing wrong?
Could you please tell me how to create the connection at the top of the frame?
Solved by HoshangMustafa. Go to Solution.
Hi
Choose Design==> Steel Connections Design. Then find the attached file.
Hi
If you are in the modelling stage, please choose Geometry==> Releases
