Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
beams Reinforcement module
4 REPLIES 4
faisal.aaouatif
337 Views, 4 Replies
Hi all ,
after calculating a building structure in RSA2013, i export beams to their reinforcement module, and i wanted to modify length of some of them ( few cm  to be in accordance with layout ) without going back to RSA and recalculate the hole structure, but the i found that the beam length textbutton is grayed.
Is there anyway to do it ( it seems to be possible with cbs ...) other than calculating beams reinforcement and exporting them to structural detailing for adjustement ( heavy procedure ...)
Thank you
4 REPLIES 4
It is possible to edit geometry of a beam but you have to select the span you want to modify first. See the attached picture.
Artur Kosakowski
Great . Thank you very much
Another question please ; how can recuperate element names ( beams , columns ) defined in RSA ( for ex Barre n°176 named Beam-01...) in reinforcement module automatically ?
No, this is not possible. You have to edit names manually.
Artur Kosakowski
Ok Thank you.
May be on a closer update , it would be helpful ...
