Dear All,
i want to make splice connection on my pinned-pinned connected beam, but which type of release should i define at splice connection point ?
pinned-fixed+fixed-pinned or without any release ? Can i define node (splice point) as pinned or fixed ?
Releases: pinned-fixed+fixed pinned (light green beam)
Releases: without any modification but it will be moment connection (fixed-fixed+fixed-fixed) (light green beam)
Solved by Artur.Kosakowski. Go to Solution.
In other words the question is how your intended connection is supposed to transfer bending moment. Knowing the answer you can decide on the release type:
- full bending moment transfer -> no releases needed
- no bending moment transfer -> release for the rotation at the connection point for one of the two beams
- partial bending moment transfer -> elastic / nonlinear release at the connection point for one of the two beams
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
