Discussion Groups
Robot Structural Analysis
stroxy
Accepted Solution
Beam Reinforcement Detailing: Shapes
574 Views, 11 Replies
02-01-2012 05:04 AM
Hello, How do I set my reinforcement pattern in the beam design module to only generate hooks at the extreme end supports?
Please use plain text.
Product Support
jad.dellel
Re: Beam Reinforcement Detailing: Shapes
02-01-2012 05:12 AM in reply to: stroxy
Hi Stroxy!
Which Rc code do you use ?
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
stroxy
02-01-2012 05:14 AM in reply to: jad.dellel
Eurocode 2 (Eurocode 8 for seismic)
Product Support
jad.dellel
02-01-2012 05:26 AM in reply to: stroxy
If hooks aren't generated, you can try to switch off the Hooks, only if necessary option:
Jad DELLEL
stroxy
02-01-2012 05:39 AM in reply to: jad.dellel
Hooks are generated on both ends of the bar.  I only want the hooks at the extreme supports and a regular lap splice (no hooks) within the span
Product Support
jad.dellel
02-01-2012 05:52 AM in reply to: stroxy
Can you upload your rtd file please?
Jad DELLEL
stroxy
02-01-2012 07:24 AM in reply to: jad.dellel
please find uploaded file attached
Product Support
jad.dellel
02-02-2012 12:59 AM in reply to: stroxy
Stroxy, can you send us only your RC beam?
The file you attached before contains all the model without any RC beam calculated.
Jad DELLEL
Product Support
jad.dellel
02-02-2012 03:42 AM in reply to: jad.dellel
Stroxy,
It should work as you excpect if you Switch to single span
Jad DELLEL
stroxy
02-06-2012 04:15 AM in reply to: jad.dellel
Thanks Jad
