Hi.
Is there a way to combine a "Beam offset" and a "Release" for an arbitray member without getting error message when executing the analysis?
I am able to use offsets and releases i the same analysis, but not on the same members.
BRGDS
FC
Hi
It did not solve the problem, I still get error messages.
I don't know if errors affects the result?
Errors disappears if I chose only to use either realease or offset.
BRGDS
Frans
You have to use DSC algorithm and that's why you have to get rid of offsets or replace offsets by rigid links.
Example:
