I'm working on some steel beam with big holes for services. I modelled them as a set of plates with correct stiffnes and was looking at von Misses stresses. Looks like near corner beam is yielding which is fully understandable. I would like to ask if there is possiblity to do nonlinear (2nd order) analysis so the stresses would get redistributed according to the defomed stiffnes matrix. I was playing with analysis type but I cant get realistic results.
Thank you fo any help.
Bart
File attached below:
Solved by Artur.Kosakowski. Go to Solution.
Nonlinear material behaviour is not supported in the current version of Robot.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
