Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Beam End Rotations
5 REPLIES 5
Burgon87
1203 Views, 5 Replies
Beam End Rotations
I am currently back analysing concrete beams. Currently the issue on site is that the concrete is spalling at the beam ends due to rotation of the beam ends causing clashing with the next beam which is due to their deflected shape. Is there a way generate the angle of rotation through the software outputs?
Help with this would be grately appreciated.
Many Thanks
James
5 REPLIES 5
Rafal.Gaweda
in reply to: Burgon87
Either check Displacement table or this :
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-nodal-displacements-in-local-c...
or I misunderstood what you want to get.
Rafal Gaweda
Burgon87
in reply to: Rafal.Gaweda
Thanks for the quick reply, however this wasnt what I meant.
I have attached a sketch to clarify my question. I am effectivly looking to resolve 'theta' B in the sketch using your software.
Thanks.
Artur.Kosakowski
This kind of results is currently not available in Robot.
See also the message 8 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Wish-List/m-p/3538438
Artur Kosakowski
@Burgon87
Some workaround - if you need values of rotations only in some specific points along the length of beam you can define nodes there and re-run analysis.
Rotations will be available in the table of displacements:
Pawel Pulak
Technical Account Specialist
Burgon87
in reply to: Pawel.Pulak
This is what I was looking for.
Many Thanks.
