Dear Sir
kindly find attached file
in pic 1 : moment of beam ( no 487-488) =3145 kn.m under the planted column . but using robot, the moment taking into consideration to design this beam iis 1496 kn.m (pic2)
Regards
Solved by Artur.Kosakowski. Go to Solution.
The values are taken from the specified number of points along a beam. Your target is the value at 7.5 m so you may use 95 divisions (results read each 0.1 m as beam has got 9.4 m).
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
