Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
rodainnajjar1229
449 Views, 2 Replies
Beam design
Dear Sir
kindly find attached file
in pic 1 : moment of beam ( no 487-488) =3145 kn.m under the planted column . but using robot, the moment taking into consideration to design this beam iis 1496 kn.m (pic2)
Regards
Tags (1)
2 REPLIES 2
The values are taken from the specified number of points along a beam. Your target is the value at 7.5 m so you may use 95 divisions (results read each 0.1 m as beam has got 9.4 m).
Artur Kosakowski
thanks
