Base Plate Design in Robot Structural Analysis Professional
9 REPLIES 9
Message 1 of 10
5301 Views, 9 Replies
in the name of  GOD .
hello to all
I don't know how design Base Plate for steel columns in Robot Structural Analysis Professional ?
did you ever do it ?
9 REPLIES 9
Message 2 of 10
AJA14
Simply select your column and go to the connections design module and choose if it is pinned or fixed.
Regards.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Message 3 of 10
in reply to: AJA14
I've done as you said but instead of base plate, column to beam is designed.
Robot can never base plate design?
please help me more
Message 4 of 10
Artur.Kosakowski
If you want to create a column base connection you need to select the column and as well as the node where you defined a support as shown on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 5 of 10
in reply to: Artur.Kosakowski
I did as you said and select column and node but the base plate connection is'n calculate for column.see attached image.Smiley Sad
Message 6 of 10
Artur.Kosakowski
I assume that actually you created the connection as  a stand alone one using the button from the right hand side vertical toolbar rather than imported it from a model. In such case use the indicated button to run verification for manually entered set of forces.
Artur Kosakowski
Message 7 of 10
is there any way to design base plate connection for column that imported from a model ?
I can't do this. the same attached image in previous reply appears.Smiley Sad
Message 8 of 10
Artur.Kosakowski
Try to follow the steps shown on the attached picture. Define a column (use any I section type), then add support. Select both the column and the node where you defined the support. Press the button indicated in blue.
Artur Kosakowski
Message 9 of 10
very nice. very good.very well . thank you
it's OK. Thanks for your quick reply really Smiley Tongue Smiley Wink
Message 10 of 10
minhal.abbass27
Hi there,
i have a question regarding base plate design which forces does robot considers internal forces in the bar or the the constraint support reaction forces from the nodes ?
immediate reply would be much apprecieted.
@Artur.Kosakowski
