Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Bars and Nodes Query
2 REPLIES 2
leegsstewart
253 Views, 2 Replies
In other frame analaysis programmes I  have used, when a bar is specified to go from node to node, and 'cuts through' another node, this one does not get any loads from this bar.
However I have modelled a simpl;e 3D grillage, and member 10 shall be idealised to span between node 8 >  107, passing' over' node 81, and is not specified to be connected to it. This member should be hogging over the full length.
 However node 81 is attracting load, when I do not want this to occur. Is there a workaround?
Many thanks
2 REPLIES 2
Rafacascudo
in reply to: leegsstewart
Rafael Medeiros
leegsstewart
in reply to: Rafacascudo
Thanks ! Works perfectly
