In other frame analaysis programmes I have used, when a bar is specified to go from node to node, and 'cuts through' another node, this one does not get any loads from this bar.
However I have modelled a simpl;e 3D grillage, and member 10 shall be idealised to span between node 8 > 107, passing' over' node 81, and is not specified to be connected to it. This member should be hogging over the full length.
However node 81 is attracting load, when I do not want this to occur. Is there a workaround?
Many thanks
Solved by Rafacascudo. Go to Solution.
Rafael Medeiros
