Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
BAR DIAGRAMS ENVELOPE - Bent Moment Values
5 REPLIES 5
Ievgen
1612 Views, 5 Replies
Hello. Please explain me what is the differenece between 2 diagrams of bent moments. Why does it have two lines?
It only has them while load combination is set (USC+ or USC-) not single load, and why does it show 2 support reactions?
Tags (2)
5 REPLIES 5
Romanich
in reply to: Ievgen
Because ULS+ and ULS- an envelope combinations.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Ievgen
in reply to: Romanich
and what is the sense? If only it was possible to show values of it, otherwise what does it show?
Romanich
in reply to: Ievgen
In ULS+ you can see min and max values that was received from automatic combinations ULS for selected component.
Roman Zhelezniak
Ievgen
Yes, I understand that. I was asking about if it was possible to get know what value did it have. Or it just shows that some other combinations have different values?
Artur.Kosakowski
in reply to: Ievgen
Robot always displays two 'lines'  (also when they have the same sign) that represent max and min values for selected load cases. In the situation when one of them was drawn 'above' the bar the min. value would be e.g. -100 rather than 0.
Artur Kosakowski
