Discussion Groups
Robot Structural Analysis
Valued Contributor
3 Kudos
BAR DIAGRAMS ENVELOPE - Bent Moment Values
927 Views, 5 Replies
11-28-2012 08:58 AM
Hello. Please explain me what is the differenece between 2 diagrams of bent moments. Why does it have two lines?
It only has them while load combination is set (USC+ or USC-) not single load, and why does it show 2 support reactions?
*Expert Elite* | International Moderator
293 Kudos
Re: Bent Moment Values
11-28-2012 10:34 AM in reply to: Ievgen
Because ULS+ and ULS- an envelope combinations.
Valued Contributor
3 Kudos
11-28-2012 11:03 AM in reply to: Romanich
and what is the sense? If only it was possible to show values of it, otherwise what does it show?
293 Kudos
11-28-2012 10:37 PM in reply to: Ievgen
In ULS+ you can see min and max values that was received from automatic combinations ULS for selected component.
Valued Contributor
3 Kudos
11-28-2012 11:34 PM in reply to: Romanich
Yes, I understand that. I was asking about if it was possible to get know what value did it have. Or it just shows that some other combinations have different values?
Product Support
760 Kudos
11-29-2012 02:11 AM in reply to: Ievgen
Robot always displays two 'lines'  (also when they have the same sign) that represent max and min values for selected load cases. In the situation when one of them was drawn 'above' the bar the min. value would be e.g. -100 rather than 0.
Artur Kosakowski
