I have a truss in which the axes do not intersect. How to solve?
Rigid Links?
Solved by Artur.Kosakowski. Go to Solution.
also have problem in adding semi rigid connections with the realease-elastic.
Error: "Excessive releases at the bar."
Why do you need the partial releases for displacements (UX and UZ) ? If really needed you should define them on either beginning or end of a bar rather than at both ends. For the rigid liks \i think it is OK to define them like in the model.
I need to add semi-rigid connections on models for displacement and rotation, then applied elastic releases. This right?
Yes, the use of elastic releases is the way of defining semi-rigid connection between elements of a model.
I need to add axial and rotational deformation in the bar. But when aprece the error bars of excessive releases
ps: I have the value of axial and rotational rigide.
How do you do?
attach imge
Just ignore the error as it is excessive. The check is incorrectly done as for full releases at both end of a bar.
which is best suited to the problem of axes not intersecting rigid links or node compatible?
