In reactions results - when i uses walls - i want to show reactions on them ?
i go to robot help but , i don't understand what this mean !
Solved by Jummybear. Go to Solution.
Avarage value is avarage value 🙂
And integral value is the sum reaction under the whole support line. For example if you have 10m long line support with integral value 500kN then avarage value will be 500/10=50kN/m
