Discussion Groups
Robot Structural Analysis
Active Member
john.sodergran
automatically generated snow / wind loads according to EC1
1817 Views, 8 Replies
02-24-2012 04:26 AM
Is there any function in robot 2012 that automatically generates snow / wind loads to an existing frame ? or
Can you use the frame generator for making snow / wind loads (all different zones) on an existing frame ?
Please use plain text.
Product Support
Rafal.Gaweda
Re: automatically generated snow / wind loads according to EC1
02-24-2012 04:41 AM in reply to: john.sodergran
It depends on national code set in job preferences. For some only 2D, for some 3D also.
Rafal Gaweda
Active Member
john.sodergran
02-24-2012 05:23 AM in reply to: Rafal.Gaweda
if the wind and snow 2D / 3D field cannot be chosen, does this mean that it cannot be used with the national code currently set ? (Finland)
Product Support
Rafal.Gaweda
02-24-2012 05:35 AM in reply to: john.sodergran
John
Yes, but select French code, then specify "your" pressures and check generated loads.
Rafal Gaweda
Member
olivierkst
05-10-2012 09:58 AM in reply to: Rafal.Gaweda
If I understand well, wind and snow loads according to the Eurocode cannot be generated automatically in RSA 2012. at least for 3D structures.
Do you happen to know whether it will be implemented in RSA 2013?
Thanks for your answer
Olivier
Product Support
Artur.Kosakowski
05-10-2012 11:45 PM in reply to: olivierkst
If you mean arbitrary shape of 3D structure then this is not possible (you can use cladding load instead) however this is possible for a  warehouse structure types that are based on number of identical frames (you enter the geometry of a single frame in a 2D Frame model and then you provide spacing among the frames creating a 3D frame model).
As we have already mentioned in couple of the topic due to the company policy we are not able to provide any information about the development plans on this forum. They have to be officially announced by Autodesk first.
Artur Kosakowski
Member
olivierkst
05-11-2012 01:02 AM in reply to: john.sodergran
Thanks for your quick and clear answer.
Olivier
New Member
bassamlubbad
01-30-2014 12:51 AM in reply to: john.sodergran
Dears :
I can't apply wind loads on the model, as its icon (Loads menu/ special loads/ wind and snow 2D-3D) is not working .
Please advise.
Product Support
Artur.Kosakowski
01-30-2014 01:21 AM in reply to: bassamlubbad
Check message 4 above and then look at the bottom picture from the message 2 for the French code 'name' :smileyhappy:
Artur Kosakowski
