I've just upgraded to RSA 2012.
The automatic redraw isn't working. Is there a place to set this?
Also, when I turn section shapes on, the elements are drawn as transparent members instead of solid elements. Can this be changed?
When I turn the section shapes off, I now see 2 red lines to either side fo the centroid. This makes snapping to points more risky. Can i turn them off? i.e. only display the centroid?
When I zoom to show the entire structure, the 2 red lines make it appear as if the elements are selected. is there a way to change that colour?
The snap settings don't seem to be working. I've created nodes down the length of a beam. I need to create beams between these nodes. I turn off all the snaps except for nodes (see page 1). When I draw the bar from a node to another node, the program still wants to snap perpendicular (see pages 2&3). Resulting in 2 nodes very close by. (see pages 4&5).
Solved by Rafal.Gaweda. Go to Solution.
Either - play here:
Look at screen shot below - "Full Redrawing ...."
As for me these lines are "ghost lines". Try to play with dislay acceleration.
Uploading of example appraciated.
Hi Rafal,
Thanks for your reply. But you missed the problem that is making my design most difficult:
No, I did not. I asked you to upload example.
Hi Rafal,
I can't install shockwave media player on my machine. IT policy.
Can you please give me a video that will play in windows media player?
.asf, .asx, .wax, .wm, .wma, .wmd, .wmv, .wvx, .wmp, and .wmx
You do not need player to open swf files.
Unzip my movie. Drag and drop this swf file into web browser window.
Hi Rafal,
I still can't access this video, don't know why, and i don't have the time to find out.
I think the video is probably going to show me Tools>Snap Settings > make sure only nodes is selected. Which I already know how to do. But sometimes, when the correct snap settings are set, the model will fail to recognise a node, or will refuse to snap perpendicular, or refuse to snap to an intersection.
BTW Those annoying red lines (ghost lines) which were appearing were the case 1 deadload 😛
Thanks for your help.
Check snap settings as shown below : - all greyed out fields should be off
Red lines - I guess graphical representation of selfweight
Look I'm pretty certain that I'm getting this right. Sometimes it just won't snap where it ough to. See my other post:
Solution 1
Solution 2
Solution 3 - results presentation - after making selection , on any results presentation window use "Open a new window" checkbox.
