I have a building in a seismic zone. I have created the seismic loads. When I try to generate automatic combinations using ACI 2002 it doesn't include the seismic loads. I can only get the seismic loads included when I change the code for the loads from ACI 2002 to LRFD. What seems to be the problem. Is that something to do with robot or am I doing anything wrong.
The seismic combinations should be generated as shown on the attached picture. In case it is not done attach the compressed rtd file please. I'll have a look at it.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Thank you Artur. I was actually disregarding the accidental loads. This works for LRFD but it seems it doesn't for ACI. I will try it when I have a chance and let you know. Thanks again.
