Hello!
I got a little annoying warning that always appears when I switch from one combination type to another. See attached picture.
Is this a bug that accures or is it something I have done wrong?
How do I solve it?
Thanks in advance
Kind Regards
Safet Iska
you must check the relations, click on the loads menu, then select Automatics combinations then select the tab relations
Each group in each nature must be moved from the Groups area to the "relations" area.
Select the first group in the area group then click on the right arrow.
You must do that for each group in each nature selectable in the pull down list nature
if few groups exist in the area "groups" in one or few nature, you must select the correct operator which will be use to combine cases of each groups
Greeting
