Hi all,
I am trying to run a modal analysis for a 12 storey complex using the block lanczos algorithm, but it crushes after runing the modes
about 40, I know I need about 60modes to achieve the 90% of mass partificaiton.
I am missing something?
Patkson.
Solved by Pawel.Pulak. Go to Solution.
Can you attach the file or give the link to download it?
Thanks for the quick response.
So please find attached model from the linked below,
http://www.4shared.com/file/hCcl7Odbba/Zone_A_model_29-11-2014_11am.html
Patkson.
there are some memory issues with Block Lanczos algorithm.
Please use Block subspace iteration method - as on the screen capture below.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
