Discussion Groups
Robot Structural Analysis
Active Contributor
WASSIMSAID1507
Autodesk Robot 2011 - EXPERT SOFTWARE
3252 Views, 5 Replies
04-20-2010 03:50 AM
Is there a new Version of the Robot Expert 2011 as for the Expert 2010?
Wher can I find it in the downloaded installation file of the Robot professional analysis 2011?
Thank for help.
Wassim
Please use plain text.
Product Support
pp2008
Re: Autodesk Robot 2011 - EXPERT SOFTWARE
04-23-2010 08:00 AM in reply to: WASSIMSAID1507
In 2011 release only some country-specific Expert modules are installed when the installation is performed in French or Polish. In such case these modules are installed together with Autodesk Robot Structural Analysis (the same position in "Add or Remove Programs").
All modules can be installed only in 2010 release - here Expert is installed as a separate application (EXPERT 2010 in "Add or Remove Programs").
Pawel Pulak
Pawel Pulak
Member
afaconsultRM
05-17-2011 07:57 AM in reply to: pp2008
Will this be corrected in the 2012 version? This is very annoying since I don't want neither the Polish neither the French version!
Will also the possibility of uninstall be corrected?
Employee
pawelpiechnik
05-18-2011 12:51 PM in reply to: afaconsultRM
Hi
The Robot Expert tools are available worldwide in the 2009 and 2010 releases only. If you upgraded from these versions it is recommended to keep using the expert tools coming from those installations.
best reagrds
Pawel Piechnik
Structrural Analysis Product Manager, Autodesk
Member
afaconsultRM
05-25-2011 10:32 AM in reply to: pawelpiechnik
I don't understand this. Why do we keep paying for updates like everyone else and the 2011 version is worse than the 2010 and the Expert is only available to France and Poland?
Active Contributor
PatrickSt-Louis5310
Re: ARSA - EXPERT SOFTWARE+ When other design codes will be available
05-25-2011 12:00 PM in reply to: afaconsultRM
I agree with this comment, bay example the retaining wall module is a usefull tool, it lwill be great if the ARSA technical team could make it available for the North American Design codes like ACI, and CSA A23.3. The same for tools ralted to the Steel & wood Structure, they still not availble for AISC and CISC.
Best regards, Patrick
