hello to all
I need information and learn more about Autodesk Concrete Building Structures.
Please learn more about this program let.
Beforehand Thanks of your help
Solved by Rafal.Gaweda. Go to Solution.
thanks but I want Learning for new versions such as 2011 and later .
what are differents between Robot and Concrete Building Structures task ? I don't know clearly.
c:\Autodesk\Autodesk_Concrete_Building_Structures_2013_Multilingual_Win_64-32bit\en-US\Manuals\CBS_manual_eng_2011.pdf
c:\Autodesk\Autodesk_Concrete_Building_Structures_2013_Multilingual_Win_64-32bit\en-US\Manuals\CBS_manual_example_eng_2011.pdf
or in similar folder on DVD \ USB
thanks . it is good reference but the version of this learning is 2010.
in Autodesk Concrete Building Structures 2013 installation files, the version of this manual is 2010 unfortunately too. please contact to Autodesk company about this to correct and update Autodesk Concrete building Structures manual document.
it is expected that Autodesk company always be update.
thanks
Nothing has beeb singificantly changed between these versions so use available documents.
in the name of GOD
CBS 2013 has not any changed with previous versions ?
in the name of GOD .
this link that is written & introduced in other place by
http://www.youtube.com/playlist?list=PL58FD78AC6AC84738
hi pro
I don't download CBS 2013
I can't sing in subcription autodesk, I'm from vietnam
Please help me ,send me link download
please help me thank all pro
mail duchoatla@gmail.com
hi pro
I am thank for pro very much
I am research for BIM Work flow standard for RC and steel , example: rac ---> rst --> asd---> robot .etc...
please help search a WORK FLOW USE REVIT
Thanks pro
yes thank you very much
But I saw this link, I don't understand apply workflows for parctice a building corporeality OR EXAMPLE BASIC
please pro help me , use workflow in desgin a building corporeality as video
that's sound good , if this tutotrial is video or file pdf tutorial .....
THANKS PRO VERY VERY MUCH
Hello to all autodesk users,
i'm frensh student drawer, and i have some question about CBS and robot. an engineer tell me that's an extension for RSA. i have downloded RSA and No way to find CBS???
Can you help me please and explain me how to of CBS.
thank you.
Ennaoui
CBS is a separate program which can calculate models on its own or using Robot calculation engine. You can also export entire CBS models to Robot or its parts to Robot's RC design modules. It can only be downloaded from the Subscription site (see the picture in the message 2 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/robot-spreadsheet-calculator-2014/td-p/43154...
Good day all
I have just download Autodesk Concrete Building Structures 2014 but i did not find the user manual, please I need to learn the CBR and if any one has any documents useful please advice
thanks
Subhi
Why need CBS? What functionality do you require that CBS has?
It's essentially dead from Autodesk perspective I think. Just use Robot.....
