Dear support,
I tried to generate a printout composition in a World documentation and I received a message (inside word) that Autodesk certification is expired.
See attached picture, what should I do? How can I validate the signature.
I am running Robot 2012 and Word 2007 (Brazilian Edition), on Windows 7 Professional.
Gustavo
Solved by Rafal.Gaweda. Go to Solution.
This macro has never been signed.
We will check what we can do. For now ignore this warning.
Dear Rafal,
but the print out is not exported to Word even if I ignore the message.
Gustavo
Hi Rafal,
all the macros are enabled (see attached), in addition of this, I installed openoffice and recieved another error message (see attached).
Gustavo
Try this
open Command Prompt as ADMIN
then
unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
(use such line as above in this Comand Prompt window)
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
then check
