Discussion Groups
Robot Structural Analysis
Distinguished Contributor
5 Kudos
Autodesk certification expired
380 Views, 6 Replies
11-17-2011 06:47 PM
Dear support,
I tried to generate a printout composition in a World documentation and I received a message (inside word) that Autodesk certification is expired.
See attached picture, what should I do? How can I validate the signature.
I am running Robot 2012 and Word 2007 (Brazilian Edition), on Windows 7 Professional.
Gustavo
Product Support
1,305 Kudos
Re: Autodesk certification expired
11-18-2011 01:17 AM in reply to: gustavo.c.vasconcellos
This macro has never been signed.
We will check what we can do. For now ignore this warning.
Rafal Gaweda
5 Kudos
11-18-2011 10:31 AM in reply to: Rafal.Gaweda
Dear Rafal,
but the print out is not exported to Word even if I ignore the message.
Gustavo
Product Support
1,305 Kudos
11-21-2011 12:16 AM in reply to: gustavo.c.vasconcellos
Have you enabled macros in Word?
Rafal Gaweda
5 Kudos
11-22-2011 01:14 PM in reply to: Rafal.Gaweda
Hi Rafal,
all the macros are enabled (see attached), in addition of this, I installed openoffice and recieved another error message (see attached).
Gustavo
Product Support
1,305 Kudos
11-23-2011 12:57 AM in reply to: gustavo.c.vasconcellos
Try this
open Command Prompt as ADMIN
then
 unregister ALL ROBOTS you have installed on your computer by command: path_to_robot.exe / unregserver
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2011\System\Exe\robot.EXE" /unRegServer
(use such line as above in this Comand Prompt window)
then
register the one you want to use.
eg:
"C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2012\System\Exe\robot.EXE" /RegServer
then check
Rafal Gaweda
5 Kudos
11-23-2011 11:00 AM in reply to: Rafal.Gaweda
Great, it is working now!!!
Gustavo
