Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Autoarch.err Error
8 REPLIES 8
Message 1 of 9
GabrieleNovembri1027
2737 Views, 8 Replies
Autoarch.err Error
Hi All,
Someone encountered the same error ?
8 REPLIES 8
Message 2 of 9
The possible reason  can think of is e.g. lost connection with a network drive where the rtd file is saved or where cfg or cfgusr folder is located. It can also be caused by the rtd file being marked as read only.
Artur Kosakowski
Message 3 of 9
Hi Artur,
Robot was running on my notebook at home and I am sure with no network drive. At the moment the program works correctly so I cannot reproduce the error. If in the future the problem appears again I will check your suggestion.
Message 4 of 9
Do you remember what was the operation that was being performed when this message appeared?
Artur Kosakowski
Message 5 of 9
sorgjee
in reply to: Artur.Kosakowski
The autoarch.err message appears quite consistently if I have two instances of RSA running and trying to save a project in the second instance. The save appears to be successfull though, so have not really worried about it.
Message 6 of 9
Hi Artur
You are competely right. I was working with two instances of Robot normally with the general model and a saved substrucure with additional constraint in order to analyze particular part of the model that is very big and my notebook is not so powerful.
Message 7 of 9
I have the same problem, but it happends when I try to open any file, even with a new project from robot templates or through open project...  any ideas?
The only way it works is double cliking an existing file.
Message 8 of 9
Artur.Kosakowski
in reply to: joh-cama
Try to rename your CfgUsr folder
"c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2016\CfgUsr"
Artur Kosakowski
Message 9 of 9
Artur.Kosakowski
Corrected in 2017 SP1
Artur Kosakowski
