Is it possible to assign elements (nodes, bars or panels) to a group and after that select then with one command? For example: I'm trying to select 8 node loads from more than 100 node loads in different stories. Is it possible to select then at once rather selecting one by one?
Solved by Romanich. Go to Solution.
Solved by Rafal.Gaweda. Go to Solution.
Solved by teixeiranh. Go to Solution.
Yes it is:
http://www.screencast.com/t/VfcZnIch9
Thanks.
Following that:
1. Is it possible to assign different elements to a group?
2. Is is possible to delete an existing group?
No
Yes, highlight group name in Selection window and press DEL key on keyboard
Use Group folders for this case
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
No
My appologies. I have forgotten.
Romanich is right.
